I've been meaning to put a switch on my torque converter clutch for quite some time and by gawd I finally did it. For those of you that don't know... The torque converter clutch is an electronically activated clutch that will LOCK the transmission to engine so there is a 1:1 spin ratio between the two. This happens at about 43mph. Up until that point, the torque converter is allowed to slip so that the engine can build more rpm's to multiply the torque output (no I'm not kidding... cool huh?)
So at ~43mph the computer grounds the purple/yellow wire on the tranny harness which locks the TCC and no longer allows the TC to slip, which gives you better gas mileage.
What I did: I installed a 3-position switch INLINE on the purple/yellow wire. The top position will make the TCC behave normally (just completes the circuit). The middle position BREAKS the circuit so the TCC is not able to lock at all. And the bottom position will force the TCC to lock up, no matter what speed. Must be careful with this --- I've heard the engine will stall if you leave the TCC locked when you come to a stop (makes sense right?)
Haven't gotten a chance to test drive it yet but I did stick my head under the bellhousing while flipping the switch and I can hear it click
I'm excited. I'll keep ya'll updated with my findings.
