Brian_B
blank
......My dad has a 1963 FE390 sitting on the floor of the garage ready to go into a Tbird........
Just curious.
Now...back to your regular thread.
Are you sure it is a 63? I thought they did not start using that until 64. I thought the cars had the Y-block still through 63. The trucks had the Y-block until 64.
Just curious.
Now...back to your regular thread.![]()
Just curious.
The birds always were different.![]()
The trucks had them until 64. At least I have never seen or heard of a stock one with an FE block.
No kidding. The FE is actually still a Y-block...if you look at the two side by side. They just stopped calling it that for some reason.
Restorers are fanatic about original parts. The t-bird group are pretty bad about that. They would rather find an original part...than buy a reproduction or a modern part.
I am semi that way under the hood. I want it to look stock (even with new parts).
Since we (I started it) managed to get so far off topic here and clutter his thread....sorry
I asked if one of the mods could split us off of this thread.![]()
All posts moved. Lemme know if this section and thread title are okay![]()
Looks like someone moved it. I forget and chat in someone's thread sometimes.
I know they do not like that.
Anyway, Mine looks pretty close to stock (just 52 years older) under the hood. Sometime when you think about it...snap a pic of your dads engine.
Bill found a replacement fuel pump for mine (glass bowl), as well as a crank pulley (NOS) that I need to put power steering on. I have the pump, pump pulley, all the brackets (repops), and the reservoir now for mine.
I still need to find the under car parts of it (54-60 full size ford) and then adapt it to my truck. If I can make it all work...it should look stock (even though it was not an option on mine).
Well yeah, if my dad ever gets around to the project (with marriage comes the burden of time, money, and resources, away from fun stuff...) he wants to keep it looking totally stock and classy, but to have modern touches (remote CD changer for instance) hidden away. Under the hood, he had the valve covers chromed (well technically not under the hood, the engine is on blocks) as well as all of the other modifications that have been done. Shows like "Pimp my Ride" and stuff are kind of a shame because I like seeing cars the way they were intended to, not all messed up.
I feel the same way. I hate seeing an old vehicle chopped up and messed up (at least they look like it to me). I do not mind modifying one for safety, comfort, reliability, etc at all.
As far as "PMR", I only recall them screwing up one cheby shoe box (mid 50s somewhere). Mostly they hacked up imports. At least the few I saw.
Mine is not quite stock elsewhere. I have carpet, a headliner, autometer gauges, power brakes, dual reservoir master cylinder, vacuum reservoir, radial tires, etc. The brakes stuff is hidden under the cab and just makes it a lot safer for as much as I drive it.
Eventually, I will have power steering and seat belts.
Mine will never be a show truck, but it is driven.
