FE or FT 361
Hi All,
I'm trying to figure out what motor I have in my old 1971 C-750 CabOver. I was hoping you could help me out.
The tag is missing off of the motor and I don't know if it is the original motor so the Truck VIN doesn't help.
I believe I have a 361 FT but I'm not positive. Most things that I have found point in that direction but I want to be sure before I start buying things online for this motor.
Here is what I found so far:
5-Bolts on Valve Cover
4-Bolts on front motor mount plate
Crankshaft Casting #D2TE6303AA
Casting on front of the block: 352
Casting on rear of the block: 352 A 55
Casting under oil filter housing: E1 1 M 11
Waterpump Casting #C8TE-8505-F
Carb: Holley 2300G Governed 2-Barrel
The crankshaft casting comes up as a 330HD or a 361 Heavy-duty Truck with 1-3/4" Pulley Snout.
It makes sense that this motor would be an FT since it's in a Cabover. However, the 352 casting on the front may indicate that it would be an FE from what I've read.
Any help you can give me would be greatly appreciated.
I can have a look tomorrow in a manual I have, it might tell me.
FT's have a bigger pulley at the water pump and higher up, and if I recall, the bypass hose to the front of the intake is around 1" or so. The water pump on FE motors are similar to a Chevy water pump, in that they do not attach directly to the timing cover.
My 71 has a 330 most likely, again as long as it is original. I haven't bothered to verify. It isn't a super power house, but gets along fine. (I have been giving some thought to going to a 6.9 diesel, since I have everything to do it...)
Some info:
http://www.f150forum.com/f2/converting-ft-block-fe-setup-189750/
getimage.php
