F350 won't crank no power to starter solenoid
2001 f350 super duty 5.4
Ok so it started the other day I parked the truck and when I came to start it It would not crank I played with the shifter nothing still.. I put in a new starter and starter relay on passenger fender checked every fuse and relay still nothing I was able to short from my battery to starter relay wire for starter solenoid and it started right up so I've limited the electrical problem to be between my starter relay on fender to my ignition and fuse panel. When key is turned I have no power to fuse #20 15A Starter Motor Relay Coil, Clutch Switch nor to small wire on relay for solenoid on starter. Any ideas would be great! Thanks
Does it start when you put it in Neutral?
