f-350 4X4 front hubs failing
102
Why do the front wheel hubs of F-350 4X4 fail at 70,000 miles. We had a vehicle's wheel hub run off of the spindle on an interstate and did $6,000 in damage to the ambulance. It was a 2000 model with a little less than 70,000 miles. Now we have a 2004 ambulance with 73,000 miles that has one real bad hub and the other is starting to make noise.
Shouldn't the hubs last longer. Why are they made where you can't lube the bearings?
Has anyone else had trouble with their hubs?
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
You say they are ambulances?
If so i think the sheer weight of the ambulance is to blame here...
I would make hub replacement mandatory after say 60 of 65k miles...
Just to be on the safe side.
102
You may be correct regarding the weight. Both ambulances were at just under the GVW limit.
We are now ordering F 450 chassis for our ambulances.
Truckin4life
9,037
San Antonio, Texas
That would be my guess then, it seems as if it has not been an isolated happening, which leads me to guess that weight would be the factor. Im not sure how often your suppoed to replace hubs, but 70k dont sound to bad...
102
Our local shop (non-Ford) recommended replacement using premium hubs. They are $400-$450 each plus labor.
Anyone know if this is an excessive amount for this work.
nobodyspecial
Fire in the hole...
5,756
366
ND
are these unit bearings? if so, then the price seems typical. They are spendy.
I just had the hub lock outs on my 2003 F350 4X4 go out. I went to the dealer looking to price the lockouts. Parts guys said it was a common problem thats why they had two in stock. Just one was $295. Any suggestion on an aftermarket replacement? I was looking at Mile Markers but they are just manuals not the "auto and Lock" type but for $150 with shipping for the pair??? It could be worth gettingout of the truck to lock them in.
