- 4
- 0
My symptoms before I let it sit for 2 years was it would sometimes die after it reached operating tempature.It would just fall on it's face like running out of gas.
It usually starts right up but now it can fail to start.
If I keep spraying gas into carb throat it seems to keep running.
I'm guessing fuel pump in the tank but the previous owner instead of replacing the filter they broke the pick up tube off and didn't put a filter element back in.Can I put the inline filter on it.It'll fit but I'll have to use a few straps to keep it secure.
What's the easiest way to replace fuel pump?I've heard taking off bed will work and pulling tank is more work.
Before I start procedure.What else can I check to make sure it's not fuel pump in tank?
Another symptom is seems to run much better at 55mph but once I let up on gas it can just stall but if I drive it real hard it'll fall on it's face also.
