Engine 6.9 hum/dron
mvc
36
From 45-50 mph, my engine makes loud humming / droning. Come by the engine or can also come from the drive?
It may well be normal, also depends on the intake setup. You get in a certain rpm range and they do drone a bit.
mvc
36
"Maybe drivetrain" - rear Drive Shaft or Axle Shaft?
"It may well be normal, also depends on the intake setup. You get in a certain rpm range and they do drone a bit."- I have no tachometer but it is very loud droning.
"Exhaust resonance" - I must try.
Can it be the transmission?
Climb under and check the universal joints on the driveshaft - they can make that kind of noise when worn
