Easy way to adjust headlights?
On the 1994 F-150...
About a year ago, I had the driver side front quarterpanel off, and took apart the light assembly. I don't feel like tearing it down again. Is there an easy way to adjust the headlights? I'm having a hard time remembering how I did it in the first place.
the chrome trim panel around the headlights is in the way of the adjusting screws. My chilton says that I have one at 12 o'clock and 3 o'clock, but does not give me a hint about how to get the trim off to GET to the screws.
Ryan, I believe you have the Aerodynamic style, don't you? Plastic housings? the screws are on top as shown.
hey! haven't had this resolved.
Anyone taken the chrome trim off of the lights of a 92-96? I can't figure out what's holding it on towards the bottom or how to get to it.
Brian_B
blank
You took it apart about a year ago and you forgot how? Your getting old and forgetful Ryan. :rofl:
As far as adjusting the headlights AutoZone tells you how.
http://www.autozone.com/az/cds/en_us/0900823d/80/0a/39/3f/0900823d800a393f/repairInfoPages.htm
Do you still need the chrome off for some reason or can you adjust it like the site says?
Now I'm onna have to find a 94 so I can talk him thru it...
adjusting is no big deal. There's a couple mount screws. I can't remember how to get the chromed plastic off to GET to the mount screws.
Brian_B
blank
Well...is there the slightest chance it is made like an 89 ranger? confused
1. Remove a bunch of plastic screw clip things across the top of the grill and headlight door (proper name on a ranger).
2. Remove the grill itself (you should be able to see the screws).
3. Remove the screws in the headlight door (chrome piece around the lights) that are now visible (were hidden under the grill).
4. Carefully pull outward on the grill side of the headlight door.
5. Slide tabs out of slots on fender side of headlight door and remove headlight door from truck.
6. Adjust the headlight as per the above instructions from Auto Zone.
7. Reverse steps 1-5 to reinstall everything.
This sound about right for your truck? I assume they are all similar.
no. I'll have to tear into it.
I may have to take the fender off again just to get to the screw. I don't have time in the near future, but I'll let you know how to do it when I figure it out.
brian, you gonna be home sunday a.m.?
Brian_B
blank
Do shops up in MO still check the adjustment on the headlights when you get them inspected?
AR did away with all inspections years ago, but even then they did not check the allignment. If you wanted them to check the allignment they usually grumbled....LOL
Anyway, the machines are long gone that they they checked them on and I need to set the ones on the 56.
I was thinking some shop across the state line might have the machine to do so.
I read that I was supposed to park something like 25 ft away from a wall and measure a certain # of inches above the mark and aim for it.
