- 6
- 0
Hey you guys, first post here, and looking to try to get my poor old girl back up and running right w/ out spending an arm and a leg! I have some wierd problems w/ her. It is a 92 f150 w/ a 5.0 4x4 and e4od tranny. The problem is that when it is warmed up it will erractically downshift to a lower gear and then shift back up to the next gear very hard. (is this slipping?) It mostly does it from over drive to 3rd and back, and it will do it over and over in a several second interval. It sometimes will do the same thing in lower gears while accelerating. I changed the fluid and filter and it seemed to help for a couple days, but now back to the same problem. I have stopped driving the truck for now and am hoping for some advice. It seems that if I use the colum and manually shift it there is no problems and if I turn off the od button I can drive it around. When I changed the fluid it seemd to be clean and red, however the magnet had a nice coating of goo on it. Anyone out there able to help?
