E4OD Violent Shifts
I was having extremely violent shifts in all gears. I replaced the TPS and now no more violent shifts but itacts like it doesn't want to shift until I let off the accelerator and press it again. Could this be the VSS on the rear diff?
Is it intermittent or all the time?
I have now replaced the MLPS Sensor. I am still having to let off the throttle to get the tranny to change gears. I have a new Tach Sensor, a new TPS ( adjusted to 1 volt at idle and 4 volts at WOT) and a new MLPS. What else can it be?
43
Have you checked the timing. My truck was doing the same thing as the distributor was going bad. New distributor and timing set correctly all shifts great. Also clear the codes before setting the timing.
