E-Fan conversion
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
finally got an Efan of an 5.0 mustang (freebee!) working great! i think its 16' or so
nway i ordered a controller from hayden adjustable thermostat 160*-220*
all i need help is how to mount this fan ?
its something like this
no shroud and only 3 mounting holes
Lost
PA Chapter leader
3,288
central PA
I saw same thing on a truck at u pull it . Had plastic pings through rad to hold it. Like zip tie only round . Where they got em ???
Good luck sounds good to me.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
Orielly's Auto parts has them I know for sure.
They look like these at the bottom of the pic....
Yeah I've used those zip tie deals before-- they work okay. 1 or 2 of mine snapped after a while of usage.
Honestly Jurgen I'm afraid that fan might not be enough... You're pushing some big power, I think you're going need something a little bigger and with a shroud on it.
F 150Cobra
3,642
104
Aruba
the fan is enough... i just gotta put a shroud on it!... im gonna make a custom shroud and install that baby :)
KdPate
After Hours Garage
Fab up a bracket that holds it on the radiator using the mounting points of the fan and the mounts when the old fan shroud bolts to the radiator.
3,291
188
In my own world
mount the fan to the shroud, and the shroud to the radiator. those plastic ties wear at your core, and become brittle over time breaking when you least want them too.
F 150Cobra
3,642
104
Aruba
what inch is that skan ??
i think mine is the same size just no shroud
KdPate
After Hours Garage
Looks like your using a Taurus fan Chris......:cool:
Its actually from a tbird. This one had a bigger shroud and fan diameter, puts out as much if not MORE cfm, and uses less power than my old taurus fan. Look at the difference:
why not just mount the fan inside of your stock shroud. use the zip ties through the rad and the existing mounts for the shroud. either that or get a mark viii fan at the junkyard.
Unless the opening on the shroud is mated to the edges of the fan, the shroud will not be fully utilized.
KdPate
After Hours Garage
Nice:cooldude:
Currently using a Taurus fan on my truck and keep looking for a T-bird or 95-up Mustang fan. Will just keep looking for now snce I've not had any issues with mine yet.....smiliegitrdone
My taurus fan used to kill my radio when I switched it on high. It was ridiculous. And it didn't cover nearly as much of my radiator. Look:
Taurus:
T-bird:
120
What year of mustang did you get it off?
