drum brake replacement
You'll be fine Steven...it's not the most fun or gratifying wrench session, but it's really not bad at all. If you have all the necessary parts, it should be about a 3-4 job if you're taking your time. Usually takes me longer because I always have problems with wheel cylinders, I hate dealing with the couple of springs...and God knows I can never remember to spray down the adjuster with PB Blaster or something the day before.
I missed this thread.
I did the drums in my 94 on the rear axle. It's really pretty darn simple. If all else fails, just make sure you do them one at a time so you can reference the original for spring size and placement. As long as you have one to look at, you'll be fine.
smokey
Hitech hillbilly
Does the brake pliers have a hook and a point.
The point goes in a rivet hole and the hook holds the spring to release or install.
Once you see how they work it is easy. I was stumped at first till I saw someone use them
Look them up on YouTube.
Sad thing is, most shoes are bonded rather than riveted any more...
