dropping oil presure
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
Weak pump, bearing clearences, pluged return ports. When the engine is cold the oil is thick but as it warms it gets thinner and if theres any excessive bearing clearences and such the psi will drop down.
smilieIagree smiliewhathesaid
How are you reading the oil pressure? If you are looking at the stock gauge, you need to verify it by hooking up a good gauge, the factory unit is not a good tool, as accuracy can be a real problem. Before you get too excited, make sure it actually is what it seems. It is normal to drop some from the cold reading once warmed up.
That does sound like low oil pressure.. My 88 drops down to zero, but the engine doesn't sound like it has no pressure. The gauge waves wildly too. I haven't taken the time to hook up a good gauge yet, but no ticking from this engine.
msb71
Virginia Chapter Leader
1,624
28
Hampton,VA
My 78 w/ 351M read just like what fellro was saying good pressure on start up , then low at idle, half at 60 MPH on highway, needle went all over the board.
Mike
i have a79 with the 351m ive had nothing but bad luck with,if i can get this 87 half rite im going to try to get that thing going,last time i had it running i could rev it up and throw a three foot flame outa both exhaust pipes,things a mess.
