door ajar switch
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
any one know how to check to see which switch or relay may be causing my 04 f 250's door ajar light to stay on?
I'm gonna have this moved to the superduty's forum to get you some answers. Welcome aboard.
My boss had this happen to his 99 but I don't remember which one it was. I think it was just the door switch.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
no prob poke around and stay, you'll learn to love it here!
03 Big Red
True Believer
41
NC
OH MAN !!! I dont have a solution for you, but I feel your pain. Can't listen to the radio with the ignition off , can't leave the keys in the ignition. DOME LIGHT!! What a pain!
I don't know for sure on these trucks, but most newer Fords have the switch integrated into the door latch mechanism.
Try spraying it down with contact cleaner of WD-40...if that fixes it, you can decide whether it's worth replacing the switch, or just re-spraying if/when the problem reoccurs.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
We usually use a scan tool to check door switches. But I recomend lubing them all and opening and closeing the doors a bunch of times to see if the light goes out. I'd say most of the time it's the driver door.
Same problem here, I soaked down the latches with liquid wrench, worked the doors a bunch , and the door ajar light stays on. Id like it to work properly , My kids ride with me sometimes, and I dont want them to fall out an open door
