- Moderator
- #1
(excerpt from FMCDEALER) You just might be a dinosaur mechanic if you........
used a Sun distributor test machine when changing points & condenser
replaced floor mounted headlight dimmer switches
drilled holes in fenders during the PDI to install the radio antennas
used empty Motorcraft tune up kits to store your screws & bolts
replaced a Ford starter bendix on a daily basis
removed the plastic limiter caps to adjust fuel mixture on a carburetor
replaced blown power valves
replaced burned out EGR plates
ever stuck a BB in the hose to the EGR valve
replaced burned out choke heat tubes
replaced a diaphragm in a VV Carburetor
installed a plastic shield on a Pinto fuel tank
used white touch paint to mark the timing mark on the crankshaft dampener
used a small screwdriver on the starter solenoid to bump the engine over to TDC
stuck a golf tee in the distributor vacuum hose while adjusting the ignition timing
repaired engine fire jobs caused by leaking fuel filter hose
still have an oil can spout in your tool box
