Dentside cruise control...again
Alright dentside cruise control experts...it looks like all the parts are there to me. What says you??? Anything you don't see??? Anything I should ask??? How much is a good price???
Yes Doug....there are two switches I believe...and an amplifier under the dash.
Amplifier???
Thank you sir...
79 Ford Truck F-150 and Bronco
Non-Cruise to Cruise Control Parts List
Special Brake Pedal [MA]
Brake Pedal Support
Brake Pedal Assembly
Special Brake Booster {denoted by serial number}
# FT 38 or FT43 (The number is on the pushrod)
Complete Cruise Control Under Dash Wiring Harness.
(includes:Speed Control Module,Horn Relay,Two different brake light switches)
Vacuum Controller with chain,linkage attachment
Vacuum Controller Bracket
Vacuum Cannister & Hose (attaches inside driverside fender)
One can install the horn pad with RESUME if they use the amplifier and horn pad from an 80's truck.
^^^For sale??? can't get the guy to respond now.
bucks77ford
We will Rise Again
2,409
101
Kasson, Minnesota
Never thought about the cruise until this thread. My 75 supercab has what I think everything there already, but I don't have the steering wheel with cruise. Not sure why the PO would have changed out steering wheels to a non-cruise one and trying to find a cruise steering wheel for a 75 is very hard unless I want to pony up almost $300 for a new one.
Hey at least you can buy them from DC....the 78-79 you are the mercy of the sellers...trust me!...:rofl: :rofl:
First off..it is called speed control..not cruise control
Second. The horn pad is what makes the speed control not the steering wheel
The steering wheels are the same.
3rd..I have tons of speed control parts for sale.
What is the last 6 digits of the VIN Ben?
Here is the list Ben.
Cruise control swap
Parts required listing.
Cruise Control Horn pad and switches
Cruise Control module (Underdash)
Cruise Control wiring (Underdash)
Cruise Control actuating device on Intake
(Carb linkage chain,bracketry,Vacuum pod)
Vacuum actuation device harness
Vacuum Canister and hose to rear of intake.
Brake Booster special for cruise
Brake Pedal & Pedal Assembly
Cruise Control shutoff switch
Cruise control brake light switch
Horn Relay wiring
2 piece Speedo cable
Speed Sensor on Speedo cable for speed control
bucks77ford
We will Rise Again
2,409
101
Kasson, Minnesota
Yes, the steering wheel itself doesn't control the speed control, but trying to find a horn pad or steering wheel with one for a 75 in good condition is hard. Later ones you can find all day long and get for little to nothing. If I'm missing something and can swap a later style wheel on my 75 column then I'm there and have one. I always thought I couldn't.
Cruise control swap
Horn Relay wiring
Howcome you called it cruise control?
:prod:
:p
:rofl:
I was brain dead the day I typed that and am too lazy right now to change it ;)
I have to get back to you on the VIN Dennis...I'll grab it tomorrow.
Still waiting......:)
Bidness man...I've been in the same zip code as my rigs for all of 6 hours since Tuesday...I'll be back in town Monday.
