Dakota Digital Gauge Help
Hello all, I have a 1978 F150 Ranger Lariat, I installed a set of the digital gauges from Dakota. Everything is working great but the Speedometer. I have followed the instructions to calibrate the speedometer, however, it still fluctuates a lot. I have no idea how fast I am going it jumps all over. Any ideas?:flag:
It would seem you have a bad signal, whether from a bad sensor or connection problem can't be said without testing.
Sparky83
Virginia Chapter member
5,571
226
Norlina NC
agreed.. sounds like a signal issue..
Have you contacted Dakota Digital for technical help? They may be able to walk you through the diagnosis.
Did the old speedo do the same thing? The speedo cable may need some lubrication, or is binding.
