couple questions
1976 ford f150 360 fe c6 with column shift
will the flow tech brand headers at summit fit? it says they will but i don't want to get them and end up not being able to use them. i will just take my other exhaust and chop it up for the headers if they work. i will only run the headers for a year or two and they are cheap so why not if they work.
and is the msd ignition coil worth buying? i have really weak spark now but i would rather get a more expensive better quality coil that will last.
and should i rebuild my dizzy or just replace it? its the stock dizzy.
I'm not sure about the headers...but the factory type coil is fine for a stock engine....you can go to the MSD coil and perhaps open the plugs up a little but I would get it running properly in stock form first.
What's wrong with the distributor?....you can replace the individual parts in it if needed.
The internals of the dizzy seem wore out so I wanted to renew it or even replace it.
