- 62
- 1
do any of you guy's know if a 4r70w was ever available in a 5.0l powered 4wd?also can any of you with 96 f150's post your computer code and possibly the part#?i'm working on an obdII swap and won't to be sure i get compatible computer.thank's
Post your calibration number off your door post and I will post both the drawing number (the number on the unit) and your part number. The part number is only used by a Ford dealer, everybody else uses the drawing number.do any of you guy's know if a 4r70w was ever available in a 5.0l powered 4wd?also can any of you with 96 f150's post your computer code and possibly the part#?i'm working on an obdII swap and won't to be sure i get compatible computer.thank's
My OBD1 95 F150 351/e4od 4x4 has catch code MOB1.
Let me see if I can work this out:
MOB1 sounds like Moby!!!
It is a rather large White truck!!!
Anyone following me so far???
Chris sounds sorta like Queequeg!!!
Starbuck: probably where Chris gets his coffee!!!
I just came up with the perfect name for Chris's truck!!!
Drum roll please!!!![]()
MOBY DICK!!!
