- Moderator
- #21
MY guess is it's the BPPV causing the problem
They seize up from moisture and rust.
If you pop the check valve out of the booster (it's just a rubber grommet that it pops into - check valve comes right out) while the engine is running you should have a chitload of vacuum on it. if not, the check valve is stuck...
Wouldn't the hardened or glazed shoes be a constant problem though? The disc pads and the brake drums are only about a year old, with no long distance driving or hard braking during that time. I changed the pads/shoes because I split one of the front hubs. Since I was already in there, I changed the brakes on all 4 wheels.
I also replaced the brake fluid in the master cylinder.A VERY late update. Temps got down into the mid-20's the other night. I left for work at 0500 and the brakes were not stiff. I'll update when the temps drop below -18 deg C.I also replaced the brake fluid in the master cylinder.
I'm getting cold just reading your post Doug! Geez....let's not rush this change in the season.....![]()
