Coffee Can reservoir receptical
Late 80's & 90's Mustangs have them located under the fender passenger side
5.0
FTF'er
1,319
64
In the Middle
Don't you have a pick n pull close by? Chevrolet trucks used the plastic ball type in the 90's, or a lot of other cars would have them too.
You could probably use just about anything like 5.0 said. If you are worried about it being non-ford just put some more twigs and leaves around it and no one will ever know :rolling laugh:
Those were not Ford.
They were made for Ford just like the same manufacturer made them for other companies.
When you say inner fender ..do you mean between the inner fender and outer fender like some were...or inner fender under the hood ?
Inner under the hood.
If you look closely where a second battery would go, under there are 3 holes
2 small and one large. The large one is where the hose goes thru.
The 2 small ones are where the bracket mounts
That is the one thing IMO that can be removed from under the hood taking up space
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
Vacuum Reservoir-9E799 = Used with Speed Control only.
19A566 = Used with A/C or Hi/Low Vent.
See post #11 for 1973/79 F100/350 & 1978/79 Bronco 19A566 applications.
