'89 F-250 460 engine. I get the check engine light on a regular basis, which comes and goes. Using the check engine light as the indicator for getting the code( 6 flashes, then 3 flashes), this is the only code that comes up.
Would there be anything else causing this code other than the TP sensor. I did check the voltage of the wiring going to the TP with KOEO mode, I get about 4.8 volts, but it is not constant. The voltage seems to jump around a lot.
Any other suggestions. I bought a motorcraft TP sensor from rock auto, but I want to make sure I am not missing anything.
