The code 332 is the only code I’m getting with the “key on engine off” test.
With the engine cold it starts fine but it will stall about 30 seconds to a minute after starting it, then it is usually hard to get started again. Once the engine has fully warmed up it does not stall and starts fine.
Can this EGR code be causing the stalling?
I have not found any vacuum leaks.....yet
