Clutch master cylinder push rod distance?
Oops. :)
{edit}
I found it in the truck shop manual! :)
I had looked but couldn't find it before. :/
The rod is supposed to allow the full retraction of the piston. :)
I don't know how this stuff works really, never messed with an hydraulic
clutch system before... and here I am modifying one! LOL :)
So does the clutch master cylinder push rod completely release pressure
off the master cylinder's piston like the way a brake system's push rod
does? :)
Or does the rod retain some pressure against the piston's internal spring? :)
Not only did I change the rod length but I didn't mark the position of the
little crank the stud is on. LOL :)
Figured it'd be indexed.
Figured wrong. ;)
No big deal if you guys can answer my one basic question tho. :)
Alvin in AZ
