check gauges?
Bax
149
3
Fl.
Well the unison ring is all clean and working smoothly. However I have little boost. All I can get is about 5 pounds max. it is a little better than before but something is still not correct. I am getting good at R&R with the turbo.
If you can find someone with an IDS or a higher end scan tool, they can command the VGT to see if everything is working on that end.
blackhat620
You Had to be There
1,687
150
Arizona
UH VGT ? IDS? Thanks for the help but you may need to dumb it down a little for me.
VGT = Variable Geometry Turbo
IDS = Integrated Diagnostic System. Ford's computer system/Scan tool that OEM Ford mechanics use to talk with the computers on your truck.
Just and FYI there are over 400 inputs on the 6.0 that exchange information with the computers. FMC has some of the most complex & sophisticated computer systems in use in the industry. Without the proper diagnostic equipment on todays modern engines & especially the diesels it makes it tough to diagnose the root cause of the problem.
A good factory shop manual would help you as well. You can purchase them here or rent access time to the online version.
www.helminc.com
Bax
149
3
Fl.
OK thanks for all the information. I guess it is time to throw in the towel and go see the dealer. Either that or pull the actuator and clean it.
Bax
149
3
Fl.
I pulled the actuator and cleaned it, still no changes , but I do now have a check engine light on.
Bax
149
3
Fl.
Running good now. Ford re flashed the computer and installed a new Map sensor, did something with the plug to the glow plug circuit and changed a fuse? Never ran better? I dont get it but who cares.
The map sensor probably repaired it. That is one of the inputs for boost.
Bax
149
3
Fl.
Thanks for the help on this. it is obvious I needed it. Now to go trade it in on a new 6.7
Bax
149
3
Fl.
There is a 6.7 f350 crew cab DRW lariat pearl white with brown rockers, tan leather inside super nice at the local dealer. I may take it for a ride.
Bax
149
3
Fl.
traded in the 05 6.0 on Saturday. Hell yes glad to be done with the 6.0 I got a 6.4 f450 lariat. Nice truck. just waiting on the engine problems. It's under warranty, whoo Hoo. I hope to be in a 6.7 before the warranty runs out.
