Changed Door Pins and Bushings
Well since I got my truck the door has been sagging, and when all the windows were closed I had to slam it hard, and on bumps and stuff it would jump and was annoying. I got the pins of ebay for like 5 bucks about 5 months ago. Finally went at it and its super nice now. Here are pics.
I also had to put a new door striker in. My bushing was all messed up. 9.95 at pepboys.
Mr. Stroker
CASE IH
3,121
67
Michigan
Nice man, Got a link? My passengers side sags down pretty far, funny how the drivers side doesnt...
Mr. Stroker
CASE IH
3,121
67
Michigan
Sweet thanks man, How hard was it to do? I assume you took the doors off?
I unbolted the door from the hing, then cut the pins and hammered them out. If I was to do it again id just cut the pins and leave the latch on the door and body so ya dont have to adjust anything. I traced out the old hing so I knew where to put it. Still had to do fine tweeks.
Lost
PA Chapter leader
3,288
central PA
I hang door from garage door track with ratchet strap is way quicker than fighting in place. U can roll truck ahead to get at bolts after new pins installed . And easy on the back to line up . Look close at hinges if old bushing is worn into hinge itself they will not last long .
I use tape to outline the hinges as not all colors show marks easy .
