wareagle
War Eagle
Okay, one more question, for now. I have the model 1940 1V carb. that I rebuilt a few weeks back. Since having issues with the replacement of my radiator I have not had an opportunity to do a good run of the engine. I did crank it for a few minutes, though, and noticed fuel leaking from where the carburetor filter (brass looking thing) screws into another brass fitting on the front of the carb. I tightened as much as I could but still notice leakage. Someone recommended using some a thread adhesive that stops leaks (cannot remember the brand but it does mention that it can be used for fuel leaks). I went to pick some up and one of the older guys at O'Reilys mentioned that you can use plain old teflon tape in that fitting. I have heard that fuel and teflon tape make a bad combination. Any thoughts???
