- 32
- 0
Need some advice on running. I was driving my truck today after installation of new heads fuel pump radiator. After driving for awhile, it started pinging if I tried to accelerate past 60. Didn't matter if it was fast or slow. I had the timing set at about 10 degrees. I backed it off to six took it out and it had no power as I accelerated up a hill. I stopped to adjust the time and noticed the paint around the exhaust ports was discolored. It also stumbles if you really get in the gas going thru the gears. It also backfires thru the carb while accelerating under a load and the water temp increases. I'm thinking the carb is too lean or maybe not the correct one. I'm thinking of buying a new one. Also the whole ignition is brand new. It also idles great and around town it is fine
