Can't find my OBD plug in, help requested
460Trucker
Has the Cat Scratch Fever
2,153
54
Road Salt Hell
Hey guys, I am considering performance chipping my 1997 F250 HD with a 7.5l 460 V8, and I am pretty sure I have an OBD2 plug but I am not quite sure what it looks like. I have been told it is under the dash to the right of the steering column, I only saw a black plug with another white plug mated with it.
Any help is appreciated. Thanks!
smokey
Hitech hillbilly
it will look similar to this
460Trucker
2,153
54
Road Salt Hell
This is the only thing I could find that looks like that...
460Trucker
2,153
54
Road Salt Hell
Thats the problem, I cannot find anything that does not have wires coming out of it, there are black plugs that are similar to Randy's picture but they all have wires in each slot or something else plugged into it.
460Trucker
2,153
54
Road Salt Hell
Randy, what do you mean by "his"?
460Trucker
2,153
54
Road Salt Hell
There is absolutely nothing on the passenger side, just some wiring going through the firewall. Sadly, no black capped objects.
smokey
Hitech hillbilly
Look under the hood on the right side I heard of a few being there on the early obd trucks
That its what I tried to type but my auto corret spell check really butchered it.
460Trucker
2,153
54
Road Salt Hell
That's where others on facebook have told me it is, I will have to look again tomorrow with a fresh set of eyes in case I am missing something. Maybe my CB radio is blocking it? I'll take it off the mount and see (Its right below the A/C and Vent controls). Thanks for all the help so far guys!
The autozone site has a neat little option of showing where locations of things are.
Just in case you need info at 3:00 am when no one is usually on here
They say:The OBD Diagnostic Link Connector is located:
Front seating area, driver side, passenger side of steering column, mounted behind instrument panel
460Trucker
2,153
54
Road Salt Hell
I checked behind my CB radio and no luck there either. Even throughout the driver's side of the engine compartment, nothing. Maybe it's a lot higher and I am missing it. Thanks for the tip Mil1ion!
Why am I thinking that this truck doesn't have an OBDII port? Wouldn't it be OBDI?
If so, it should be near the driver's side cowl under the hood.
That could very well be,With it being a HD withthe old body style it might not have the OBDII just the older connector
That was my understanding. smilieFordlogo
460Trucker
2,153
54
Road Salt Hell
Thanks Austin! I looked at that and wondered if that could be it. So does this mean my truck requires a certain kind of chip made for an OBDI?
