Just for the sake of conversation...The C6 in the Bronco is getting on up there in age, and I've just assumed it's needed to be rebuilt. I'm completely transmission ignorant, but I've brought the bands in to spec, fluid looks good with minimal metallic...and the trans works well on the whole. Perfect running trans when it is cold, or the ambient temp is sub-70*. However, as the trans temp starts creeping when the ambient temp gets hotter, the 2-3 shift gets all kinds of sloppy. Will rev up somewhere around 4k and then slide in to gear. 3-2, 1-2, 2-1 shifts and reverse have never had an issue. When I re-did the engine, I took the original TC out and replaced it with the one bolted attached to the back of the replacement 400. It was flawless for a year or so. Anyway, the eventual plan is to rebuild anyway...just wanted to learn how to diagnose that symptom???
Side note, when it does get rebuilt I am planning on using E4OD/4r100 planetaries. Anyone have any good write-ups on that swap???
