breakin in period?
973
11
ok, mine was a COMPLETE rebuild as well, they DID NOT replace the solenoid pack or valve bodies.. as i said, complete usually means planetarty gear and clutch plates.
if they replaced the valve body and pack, well they migh as well have just given you a whole new tranny
973
11
its that OR they didnt put a filter on the tranny.
cause i had a ranger come in, took a minute for it to engauge into drive.. OD light was flashing.. or, the filter is plugged..
if ur that pissed, take it back to them
A_G
wuh?
3,188
74
Tulsa, Ok
i am, im sorry but what do soft parts, and some hard parts cost around 500 with a 25% mark up.
973
11
one word, LABOR lol
A_G
wuh?
3,188
74
Tulsa, Ok
yea i know, im still pissed
973
11
i feel your pain, trust me, i dropped over 2 grand on mine.. torque converter and all
A_G
wuh?
3,188
74
Tulsa, Ok
im gonna go talk to em today and see what they say, probably end up just replacing it mysefl.
973
11
y? there SHOULD be some form of a warranty on there work.. for only 25 miles and you get that bad of a slip?
A_G
wuh?
3,188
74
Tulsa, Ok
iono got to drop it off today at the shop.
A_G
wuh?
3,188
74
Tulsa, Ok
mechanic pulled the codes and the code was a converter clutch (no signal).
Thinking its a wiring problem.
A_G
wuh?
3,188
74
Tulsa, Ok
he said it was coming up as no signal
IONo
the TC is brand new though
663
IONo
Yeah I believe no signal is what mine said too, and it just gave extremely firm shifts--- no slipping.
How do you know the TC is new? Did he say so, or did you put it in?
A_G
wuh?
3,188
74
Tulsa, Ok
he said so.
A_G
wuh?
3,188
74
Tulsa, Ok
ill probably ended up chatting with him tommorow. IM tyring to get my multi meter from my old roommate. You dont by chance have a schematic for this?
He also said it wasnt a for sure being the problem, he still has to follow through on it.
i would bet that he would have replaced it, beside she did a bunch of work for pratically nothing. Like re-welding my drive shaft and balancing it. and yolk.
No install cost on ujoint. no cost of fluids
663
The wire for the TCC is the purple/yellow-tracer wire coming from the transmission harness. It's easiest to find it on the driverside wheel well, if you trace the wire loom up from the transmission.
The wire gets grounded when the computer tries to lock the TCC.
A_G
wuh?
3,188
74
Tulsa, Ok
im think theres and open to ground or something.
Maybe the wire got brittle ande cracked and vibrations make it loose contact
A_G
wuh?
3,188
74
Tulsa, Ok
just talked to them, Looking like a solenoid or a break in a wire still. All under warranty, But they are fearing pulling it again and sending it back down there so the tranny shop can re-rebuild it the right way.
My mechanic is pissed
