Does the 68 f100 braking components share parts with the 72 to 74 's like
the brake wheel cylinders?
Thnx...much appreciated!...
Looks like the rear brake cylinders will work but the fronts are different as are the master cylinders.
Just my two cents if you are thinking about swapping from a parts truck, no more expensive than they are, I think I would just get known new correct parts or rebuild the current ones.![]()
I find that rear cylinders are largely commonly available, but fronts tend not to be so much for some reason...
And as far as part numbers go, they are not a match. However, they are available from places like Rock Auto.
Well, I have also found that 76 Chevy and 75 Ford rear 3/4 ton wheel cylinders interchange as well, so you never know. st isn't a good way to know if they will or not. Mostly physical dimensions, bolt up, and pipe hookup are the things that need to be the same. Now if it is just a rebuild kit, bore is the important question. As such, I see that the bore on the 68 is 1 1/8", while the 73 has 1 1/16" bore.
It sounds like you have this covered already, but for the benefit of a future google searcher, I purchased all of my brake cylinders, soft lines, drums, and spring kits new at o'reilley's auto parts. (You will need an old school machine shop or a swage cutter to separate the front drum from the hub. If replacing the drums) Their water pump was awesome too! It came pre clear coated to prevent rust, not bare like many of the other chains. 68 - 72 are the same. 73 gets different. Each wheel uses a different cylinder due to the position of the incoming line and bleeder and the fact that the front is a beefier setup.I put a master cylinder kit in today...Lol
I was wondering what those xtra parts where ,the little o-way valves &
spring that go inside behind the brake line fittings ,they were rotted.
I replaced those as well.
Overall ,it feels good not to have to pump the brakes 3 or 4 times!...
It brakes nice an easy as soon as I start pushing on the brakes an
holds solid.....
So that what they should feel like!....
Sent from my HTC One_M8 using Tapatalk
