Brake Shim
I am putting disc brakes on my 66 f100 using ibeams from a 70's f100. I am wondering what hardware is needed for the disc brakes. Specifically if they use shims. I believe I'm missing the part closest to the caliper in the image posted.
Thanks for your help.
Sent from my Pixel using Tapatalk
Jasperrc
Texas Chapter member
What year models does that drawing refer to?
You can buy those parts as a kit from auto parts stores or online.
My 77 does not have that extra wedge piece you are referring to. You might need to look up the specifics on the axle/brake setup you are converting to.
3,291
188
In my own world
that keeps the pad from rattling
comes in a hardware kit
3,291
188
In my own world
rockauto sells just the clips
CARLSON H5412 {#HW5412} Info One of our most popular parts
Front; w/Disc Brakes; D50
x8
$0.33
or the whole kit
EIS H5515 Info
Front; 1/2 TON and w/Front Disc/Rear Drum
Choose:
[Wholesaler Closeout -- 30 Day Warranty] (Only 2 Remaining)
$0.68
3,291
188
In my own world
your brake pads have them on both ends
Jasperrc
Broung14, are you referring to the long wedge shaped piece shown between the caliper and the caliper support spring or the anti-rattle clips on the pads themselves shown at the bottom of the diagram?
My '77 F100 does not have the long wedge shaped shim piece I was referring to that is shown above but it does have the anti rattle clips Charlie is talking about.
It might be best to identify your new axle and figure out what came installed on it.
Here's what my set up has and likely yours too:
3,291
188
In my own world
The spring and cap hold his caliper as a spring slide aginst the bracket
the bolt holds it in place
It's the same as yours
I looked his parts up as 1974
