body swaping
Lost
PA Chapter leader
3,288
central PA
Not without major cutting of bed about in wheel well area . All body mounts to fab . But they r good trail rides .
Its up to u anything can be done with time and $$$
nobodyspecial
Fire in the hole...
5,756
366
ND
are you talking about just swapping the cab, or shortening the box and using that as well? I will suggest swapping the cab, and then welding up a flatbed of sorts. I am starting on something similar, but with a 72 F100 and a 79 Bronco.
Make sure you take pics if you start it.
lostinfords
New Jersey Chapter member
227
17
Jersey shore
???? why switch a 78 body onto a 90 bronco and downgrade to the ttb front axle?? it may be easier to swap the engine over to the 78....
Anything is possible...you making a truggy? But if you're just looking for a swap and hoping the wheel bases are the same, they're not. So it'll take some modding and fab work.
nobodyspecial
Fire in the hole...
5,756
366
ND
He never said his 78 was a 4x4... something to consider. It could be a 2wd, or messed up or something. We have very little info to work with here. :D
885
53
Bronco should be around a 104", your shortbed is 117". It will take some mods if your planning on a cab and bed swap.
