axles
I think CaptainP4 did a swap like that in his Bronco...I'm sure he will post something up on it...I think he used a 60 up front and a 14 bolt gm corporate in the rear.
A HPD60 from a 78/79 250 SnoFighter or a 79 350 will be the closest to a bolt up as you'll get considering you'll have to figure out if you're gonna go with what springs you have (coils) or the leaves the 60 would have...beyond that, it'll basically be plug and play.
Yeah i dont know now if i want to do a axle swap im thinking the tires im putting on are only going to be 35's the stock axles should handle that.
Yeah...35's will be about the max if you plan on doing any moderate wheeling. Personally, I always liked collecting parts, then run them til they break.
I think UTfball68 (Ben) is running 35"s on his Bronco with a D44/9in setup.
Yep sure do...but I know the limits...mainly mud and mild trails.
