AOD Rebuild.
Ridgerunner
573
Stillwater Ok
How hard is it to rebuild a AOD transmission? 85 F150 5.0 MPFI AOD Trans.
Ridgerunner
573
Stillwater Ok
Also what are the weakness that I can improve on while I have the trans out?
As with anything, careful is the name of the game. Automatics have 2 basic rules, keep everything clean, and dont force anything. Start at the convertor, and work your way back laying out everything in order. You can match up lip seals and gaskets as you go. Pay attention to the orientation of all snap rings, clips, and clutch packs.
Ridgerunner
573
Stillwater Ok
Thanks I have found a good trans kit to buy locally. Can a shift kit be added in at the same time?
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
When installing the shift kit it has you remove clips, springs and valves be carefull not to let the clips or springs go flying they tend to be easily lost.
