another exhaust thread!!
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
ok i have longtube headers NO CATS
and 2 hooker aerochambers 2.5" center in offset out
i want an H-pipe somewhere
and im debating on:
(A) Dual exit passenger side (gen2 style)
(B) 1 pipe exit on each side before tire facing outwards like kind of hidden not with chrome tips or nothing ( dont worry i dont have the front tank anymore)
(C) 1 pipe exit on each side before tire with turn downs 45degrees facing outwards ( dont worry i dont have the front tank anymore)
(D) dual turn downs after axle one each side..
i dont worry about it being louder or nothing i have a set of these installed at headers to open when i want
LEB Kris
Kris
449
17
SC
to determine the correct place for an H pipe you need to run the exhaust without it for a little while. Spray paint the exhaust pipe about 3' with regular spray paint - not temp resistant. The exact point that the paint does not burn off is where you want the H-pipe
I like option A
F 150Cobra
3,642
104
Aruba
I like option A
oh really ? cool.. soo 3" after the headers? or what?
LEB Kris
Kris
449
17
SC
no its farther...more like 12" but its different for every motor.
F 150Cobra
3,642
104
Aruba
ok ill paint a long part of the exhuast with normal paint and we will see then
countryboytn
'78 Bronco owner
4,371
204
Cincinnati, Ohio
I like options c and d... I couldnt make my mind up which I liked better...
flareside_thunder
7,812
246
I like a and d...d gives it that retro rod style while a gives it the newer style....that and I'm biased toward it cause that's how it was on my truck.....I didn't ever hear about the trick with the paint Kris Thanks......wouldn't an X pipe deliver better power though?JAT
F 150Cobra
3,642
104
Aruba
i think im going Gen2 exhaust..style less drone.. and when things get serious ill just open up the cut outs :)
a set of these at the end just before the tire
http://summitracing.com/parts/JEX-PAC418SS/?image=large
flareside_thunder
7,812
246
uhh right now...half arsed.....dual strights 2 1/4 going into a 2 in one out Thrush welded somin out 2 1/4 straight back and dumping out with a turn down angled down and to the side right at the back corner....
