- 9
- 0
Hello,
This is my first post to the forum. I have a AC compressor issue. My serp. belt broke the other day. I looked and the tensioner pulley was broken. Replaced the tensioner and everything was fine. I heard a rattling noise by the AC compressor, but when I turned on the ac the noise went away so i didnt think to much about it. That night I stopped to eat on the way from work, when came back out and the truck wouldn't turn over, barely cranked. I thought maybe the ac pulley seized. So I removed the belt and the truck started right up. Today I took the clutch/pulley off the ac compressor and the ball bearings fell all over, bearing was wiped out. If I replace the bearing will this solve my problem? Basically im wondering how to determine if the compressor is seized or the whole issue was just the bearing. Don't know if I should replace the bearing, new clutch/pulley assembly or put in a new compressor ?
Any info would be appreciated. I need to truck for work Monday so I was hoping to repair it between now and Monday or Tuesday at the latest.
Thanks !!!
2003 F250 SUPERDUTY 5.4 ENGINE
Thanks !!!
