A/C Vent Hole in Dash
78F250
New Jersey Chapter member
Sometime ago the PO had removed the factory air. Well, that left a nice square hole in the center of the dash. I've been trying to come up with a way to make it less noticeable. Maybe a panel with aftermarket gauges. I would greatly appreciate any realistic ideas you all might have.
tanman722001
Not A Chevy Man
You could make a panel and put some gauges in it or do like i did to my parts truck and weld a panel in the hole and smooth it out.And it would look like it never had one there.Or find a non AC dash and swap it.Just a idea
gsxr1238
Be fast.....or be last.
Awhile back i had to replace the dash mask over the gauge cluster in my '78 F250.The only decent mask I could find was made for an a/c model,so it had a vent register over the headlight and wiper switches.I pulled the register and cut a piece of polished aluminum plate and bolted it over the opening.Then i cut a hole in the plate and installed my vacuum gauge there.Turned out really well,and now the gauge is more visible than it's old location.Hope that helps.
I suggest a clock ....
x 2 on the clock idea.
bucks77ford
We will Rise Again
2,409
101
Kasson, Minnesota
I like the gauge Idea myself.
Wow maybe you can put a small dvd screen in that hole!
Okay I would like to add
GPS Unit
An MP3 player.
Ok no more suggestions or I may want to swap in an a/c dash just to put something in :rofl:
Good to see people from NJ showing up. Maybe we can start a chapter soon
Yes it is a daily driver.
UNRULEE
^LARGE carbon footprint^
5,412
424
Coal Country, ND
Depending on your fab skills, or wallet size, you could do this.
Pretty sweet looking!
