- 4
- 0
New guy here looking for some help. I have a 94 F150 with a 5.0. I had the motor replaced a few months ago and got an issue with the change. I get a vibration at 1500 RPM and it goes away as I throttle past 1500. I have the EGR vacuum line blocked right now but it is alot worse with the EGR hooked up. I have looked for vacuum leaks and repaired one but the problem is still there. It does it in Park and Neutral and can be felt while driving at normal cruisng speed of around 55 to 60 because RPM is around 1500 at those speeds. Any ideas? Thanks for any help.
