- 3
- 0
I just bought a 93 f-150 real cheap and it has 2 problems. The headlights go out for about 3-4 minutes and then stay on for about 3-4 minutes. I pulled 1 of the large fuses under the hood and when I pulled it the headlites went out so I assume that fuse controls the headlights. But Im not sure why they go on and off. Next problem: The automatic transmission kinda slips like a standard transmission. It takes off fine without slipping and its shifts fine without slipping. The problem is when you are moving in 3rd gear and accelerate even moderately it kinda slips or shudders just like a standard shift does when the clutch is weak. If you accelerate very very gradually it does not do it. Also you can accelerate hard from a complete stop and it does not do it either, only when you are moving. Turning of the EOD button does not make any difference. It was 2-3 quarts low on fluid when I bought it so I added a quart of lucas and 2 quarts of fluid to bring it up to full. I have a very small investment in the truck and the 4.9 inline 6 runs like a sewing machine. I would appreciate any info, thanks.
