90 F150 Motor Swap
So yea my buddy bought a truck, from his friend, and it needed a motor. Its a 90 F150 5.0L AOT 4x4, standard cab,long bed. It has a body lift on it, and its in fair shape. We pulled the motor out tonight, started after work at 6 got it out at 9-10ish. Ill post some pics in a bit.
Here are some pics, the new motor is a rebuilt peice we picked up for 300 bucks from craigslist. Supposed to have a RV cam in it. Hope she works out good. Just got done drinkin beers and I can manage to post some pics.
My friend Caleb, its his truck
89frankenford
Grabber Green Consultant
4,547
147
NH
whoa that truck looks...very uhh....used haha
nice truck though. hope the new engine works out great!
Yea im a get a nice paint job on it for him. Will be back in mint condition soon.
Was just gonna say that, we got the new motor all asembled last night, except for the intake which was dryin out from cleaning it.
Sittin in a pool of its on blood. HAHA
fordman76367
Texas Chapter member
426
4
ya see.....the reason the paint flakes off on fords is because.....these trucks are made so well and so solid...nothing can be completely perfect...so they let the paint flake
Some 5/8x1" coarse thread bolts will plug the holes in the heads under that crossover tube if you want to avoid a possible furure exhaust leak.
Hopefully the "RV cam" won't upset the EFI too much.. if it's a carb grind the motor won't idle very well but should make good power, depending what the truck is used for the owner may even like it.
Yea i just did this caus hes on a budget, plus it was late. It wasnt leakin on the other motor, it will be good on this. The motor was for a EFI truck, so I hope the cam is EFI friendly. Well see.
We got it all together except for the upper hose and fan shroud. Even got the long tubes on. The ones we used were Hooker's and the drivers fit perfict, but at last the drivers fit like crap, had to bend some tubes and weld em to each other to hold them together, and notch the frame a bit, and then cut the collector, and make it point away from the trans pan. I came out happy with it, have to make the catless back tomorrow or monday. We didnt fire the motor up caus we couldnt get it too. after playin with the dizzy and finally havin enough. We called it quits. After thinkin for hrs in my head y it didnt work, i finally figured it out. I had my buddy put the wires on, and he went clockwise with the firing order, damn it. Will try to fire tomorrow.
Here are some pics.
FIRED IT UP YEAAAA
Man you even sprayed the coolant bybass hose and all. LETS GO FORD
flareside_thunder
7,812
246
Gawd...wish my engine bay was that clean lol.....good luck firin it over man.......make sure you've got the correct order as well.....15426378
Lol no long tubes fit on anything I own, 1 side does, 1 fits to the point of shootin my self in the face. I had the order right, just goin clockwise a 1am, No wonder it wouldnt start. I does run very good and I made the exhaust up today. Still no upper hose, or coolant lol.
Yea Hooker didnt give me any collectors so I had to steal em off my red truck.
Just an update. Truck is running great other then the melted plug wires which a solution is commin in the mail tomorrow. Short plugs and high temp wires. The shifter hits the exhaust and doesnt go into drive, damn it have to fix that.
