- 5
- 0
87 F-150 2wd. 5.0L automatic. Right front caliper hangs up. We have replaced everything including, brake fluid, rotors, calipers, all brake lines, master cylinder, rear shoes & drums.
Problem- after a few miles only the right front caliper starts to hang up.( Have replaced both ball joints also & checked alignment) causing a shudder. It gets so hot wheel bearing grease melts into liquid. Ford dealer service gave some advice ( had previously been addressed) but everything mechanical has been replaced.
WTF- how does the RABS effect front brakes & could the module be culprit. Anti lock light is now on and previous owner ( my brother ) says NOT on before brake problems ( master cyl. first part replaced).
If that could be culprit without spending more $$$, how could I check.
We inherited this from him, as a gift to daughter, tired if F-ing with it, just want to fix...
