460 Conversion
Ridgerunner
573
Stillwater Ok
fatdan460
BANNED IN MOST PLACES
274
13
WENONA, IL
yep, i bought mounts from them a while back for way too much. the perches and mounts are crazy expensive for what they are, but for some it's cheaper to spend the money, like me. no fab tools.
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
what i did was.. yank out the whole cumputer and most wires and just plumbed a new fuel system pump / lines / regulator
http://www.summitracing.com/parts/SUM-PUMPKIT7A/
you can use this
http://www.summitracing.com/parts/SUM-TANKKIT3/
but i made a custom fuel pickup system using the old stuff and a new hose
note i didnt use the plastic line i bough an expensive piece of hose that is rated to be in gasoline and stuff
the only electrical stuff on my truck for the fuel is this piece
http://www.summitracing.com/parts/SUM-890023/
i put a swich on the dash to turn it on and off when i want but thats optional
Take a read in the project cobra thread in the first pages or so you will find something about fuel delivery
Ridgerunner
573
Stillwater Ok
Any way to use the low pressure fuel pump in the tank? Or if I can use the mechanical pump on the 460
F 150Cobra
3,642
104
Aruba
i dont know how much psi the low pressure pumps puts out a carb should be around 6-7 if its so your allright
F 150Cobra
3,642
104
Aruba
i have no idea.. my guess is you find the wires of the pump and connect it directly so it turns on when you turn the key to on position. and with an switch on the dash for safety
Ridgerunner
573
Stillwater Ok
Did you remove the wiring for the computer?
