351C question please
found a 74? f250 4wd and the cyl head has a "2" in the corner, I know this signifies 351C 2 bbl heads, but do these heads fit other blocks?
Is this a cleveland for sure?
thank you FoT
the VIN is X265KA------ fordification does not seem to decode this year
384
The trucks never came with a Cleveland in them.. But the 351m's and 400's did.. And they can use the same cyl heads... But not the same intakes cause the difference in deck height.
The 5 in the VIN# is wrong, it should be a letter
No C block in Trucks in the early 70's.... not under 1977 were the 351M/400 available in Trucks
I suggest it has had a replacement engine if not an FE
The 2 doesn't represent anything for IDENTIFICATION Who told you it did ?
What format are the spark plugs in
this one : / / \ \
or this way: / / / /
How many valve cover bolts ?
Wet or dry Intake
Casting numbers or firing order ?
I did not get that close of a look. It is not FE for sure, i wish it was.
cleveland heads all had a BIG 2 or 4 in the corners near the intake. I'll do some more digging, and get the year and a better look at the VIN, and the engine.
Don't go by that 2
That is your first mistake.
Go by the info I gave you.
I need to get a better look on monday, I'll bet you a dollar they are cleveland heads :>)
I will check the info you gave me for sure though, I can be taught, most days
