351c in a 79
Bloodhound
Oilfield Trash
What would it take to put a 351c in a 79 Bronco.
I think it is a big block with a small block tranny.
If it is a manual you would need a smallblock bellhousing. If auto you need a new trans. for a smallblock.
I have used it too... took out a 460 that was smoking nicely to put the Cummins in.
That will keep you busy for a while if you go that route... Lots of computer work to figure out.
Indeed. Tons of electrical requirements on that engine but if you can find a complete donor truck, you should be able to pull everything you need to make it run in the older truck. Mounting and driveline will be a challenge though.
Bloodhound
Oilfield Trash
I actually have thought about shorting the frame on the 96 F350 and mounting the Bronco body on it. That will give me Dana 60 front, 10.25 rear, 7.3 powerstroke w/ 5 speed.
Not gonna lie...that would be pretty awesome. There's actually a wrecked 97 350 4x4 on nc4x4 right now. The front end was crunched, but no structural damage. He's parting it out...but I'm sure he'd sell as a whole.
