- 2
- 0
Please allow me to pick your brains about a problem I'm having.
I have a 2000 Ford Ranger 4WD
3.0L Flex Fuel 6cyl
California Emissions
4 wheel anti-lock brakes
49,000 miles
I'm getting a load rubbing sound and steering wheel vibration which has been going on for quite some time (1 1/2 years), but getting progressively worse. The sound is similar to metal on metal brake grinding. Here's the kicker, it gets worse after engaging and releasing the 4wd.
The front brake calipers, pads and hardware were replace a month ago and the rotors are within factory specs, have no heat scoring and there's no brake pedal pulsation.
I've inspected the front end.
No ball joint movement (loaded and unloaded)
Inner and outer tie rods have no movement and there's no excessive lash in the steering rack.
Visual inspection of the wheel hubs; no heat scoring or any lateral movement.
Now, this particular model doesn't have locking hubs. It locks via an electric motor on the transfer case, which was defective, replaced and is working properly.
The front drive consists of a drive shaft, from the transfer case to the front differential. The differential is connected to the wheel hubs with 2 CV joints.
A visual inspection of the front drive shaft and CV joints reveals no obvious signs of wear or movement. The CV boots are intact and undamaged.
This is blowing my mind. Has anyone ever experienced an issue with this type of Ford setup?
3.0L Flex Fuel 6cyl
49,000 miles
