our white 88 had a AOD from the factory with a 5.8. i have decoded it enough times along with the button on the dash.
I got my doubts this truck actually has an AOD, as far as I know the AOD was never a factory option behind the 5.8 in trucks, only behind the 4.9 and 5.0. There are several possibilities here..
A) the AOD was swapped in
B) it's actually an E4OD with the kill button on the shift lever or dash
C) the truck actually has a 5.0 and not a 5.8. The early EFI intakes did not have the engine displacement on the upper and a lot of people can't otherwise tell the difference between these blocks.
I'm guessing it either has a 5.0 L motor, or a has had a tranny swap. As already mentioned, the 5.8 wasn't available with the AOD. Here's a page from the brochure.
On another note, those ultra-low-mileage older units don't fascinate me much. past experience tells me there's a lot of deterioration going on as they sit- even if it's indoors. Give me something that's been driven daily anytime.
if you look at the dash it will be on the right side of the dash just under the gauge cluster.
Does the AOD say OD on the cluster? My e4od just says D 2 1.
