- 22
- 0
78 F250 4x4 AT without tilt. i had someone in last few months replace shift collar. Shouldof just done it myself as they didn't do the greatest and shortly thereafter to make matters worse the hole shift tube just "broke loose" and spins. I took the wheel and everything apart recently to assess the situation. My main question is how do you properly install the shift tube to where it engages the shift fork properly? I have the shop manuals and the diagram but was hoping for some practical advice/tip. I currently have everything removed now except the outer housing (steering column assembly to use manual lingo)and the shift fork. The manual refers to a "wave washer" --that i'm not sure I have---perhaps it's in there I don't know. I'm wondering if there is a problem with my shift fork.
thank you !
thank you !
