Brought the truck to the Stealership and just as I predicted they found nothing wrong....$150.00 out the window.
So I step on the gas and the more the pedal goes down the more it bogs down and wants to stall.
So far I have: Changed the fuel filter
Cleaned the MAS
Changed the air filter
checked for vacuum leaks
Ran a few tanks of fuel injector cleaner ...
Some codes showed up at autozone when the check engine light came on
0171, 0191...lean codes
So what's next to check? o2 sensor? Bad Cat? Fuel rail sensor? fuel pump?
I dont wanna start throwing money at parts... thanks in advance
Cleaned the MAS
